Optimizing code
By Andrey · 2021-04-09
Hello
I am trying to optimize my code. Need to select a object class in a specific layer.
I am working with code that consists of two stages:
1: Selecting all objects in the layer.
2: Selecting splines from selected objects.
local allNodes = #(), theNodes = #()
for n in selection do (n.layer.nodes &theNodes ; join allNodes theNodes)
select allNodes
select(for obj in selection where classof obj.baseObject==line collect obj)
I am looking for a way to exclude the first part while keeping the result.
Any ideas on how to do this? Any help appreciated.
Comments (12)
	allNodes = #()
		for obj in theNodes where classof obj.baseObject == line do
			append allNodes obj
	select allNodes
Reply to miauu
Panteleev Sergey
What if selection contains several nodes that belong to the same layer?
You'll have n^2 results in allNodes array if all selected nodes are lines and belong to the same layer
LayerManager.deleteLayerByName "layer #1"
layer_1 = LayerManager.newLayerFromName "layer #1"
for i=1 to 100 do layer_1.AddNode (line())
layer_1.select true
	::allNodes = #()
		for obj in theNodes do
			append allNodes obj
	select allNodes
	format ">>> %\n" allNodes.count
>>> 10000
layer_1.select true
	::allNodes = #()
			appendIfUnique allNodes obj
	select allNodes
Reply to obaida
Panteleev Sergey
layer_1.select true
	iterations = 0
	::allNodes = #()
			iterations += 1
	select allNodes
	format "iterations: %\n" iterations
>>> 100
iterations: 10000 -- n^2 is still there ;)
sometimes using try()catch() is better than wasting time in solving all cases with errors
same as your case cuz it take seconds ;)
but if u care about the iterations go ahead :)
Reply to obaida
Panteleev Sergey
try catch? but how does it help you here?
Just imagine a user having 10.000 lines in a single layer. Possible? Easy. Still seconds?
10.000^2 is a pretty large amount of work. I bet max will hang for a long long time or just eat quite a lot of ram and crash after that.
I'd save a scene before any attempt to run a script with n^2 solution. ;)
That's why I posted the example to demonstrate the issue.
If it isn't a problem, ok.
layer_1.select true
	iterations = 0
	allNodes = #() ; layernames = #() ; theNodes
	for n in selection do appendIfUnique layernames n.layer.name
	for i in layernames do (
		layer = LayerManager.getLayerFromName i
	for obj in theNodes do (
		iterations += 1
	select allNodes
Reply to obaida
Panteleev Sergey
	all_nodes = #()
	tmp = #()
	for layer in makeuniquearray (for s in selection collect s.layer) do
		layer.nodes &tmp
		join all_nodes tmp
	arr = makeUniqueArray all_nodes
	format "%\n" arr.count
