I'm having trouble with something I thought would be easy. I'm trying to open a directory with the right path. I loads fine but just wont actually open the file when I click the open button.
on btnOpenSce pressed do (
--local lightmapTex = getOpenFileName caption: "Select the Lightmap" filename: maxFilepath types: "Images (*.dds, *.jpg, *.png, *.tga)|*.dds;*.jpg;*.png;*.tga"
saveloc = ((PROJECTS[ProjectList.selection][2]+cats[objList.selection][2]+dirdd.selected)+"\\02_3D\\"+"")
save01 = getOpenFileName filename:saveloc ()
Max File
I'm just trying to create a shortcut to a folder. Then open any of the max files in that directory. Do you have to specify a file for it to load?
this is a different story then :)
The getSavePath displays a folder selection dialog where to select your folder. For example:
And use loadMaxFile function to load the .max file.
display bitmap ?....or display save01...
open bitmap?
getOpenFileName() is just a file selector that not load anything, it just return a String (the selected file name). openBitMap() and selectBitMap() will load a bitmap.
