Hi all. I'm making a dynamic menu bar in maxscript. I'm having a little bit of trouble opening up the right file path. I'm looking through folders then wanting to open the directories in the right place.
in short this is what I'm having trouble with:
str = "macroscript smartmenu_scene" + (ii as string) + " category:\"smartmenu_scene\" buttontext:\"" + (getFilenameFile i) + "\" (getOpenFileName filename:scenefilepather \"" + i + "\")"
execute str
Here is the whole script for a little more reference:
--Project Grabber
ProjectPath = "C:\3dsmax2013\3ds Max 2013\scripts\Project Manager\CurrentPrj.txt"
ProjectText = openFile (ProjectPath)mode:"r"
while NOT eof ProjectText do
oReadLine = readLine ProjectText
--filepath.caption = oReadline
close ProjectText
scenefilepather = "G:\\" + oReadline + "\\B_JOBS\\06_15137_CENTRE_POINT_SET_06_INTERIORS_AMENITY\\02_PRODUCTION\\"
dirArray = GetDirectories (scenefilepather+"/*") --//Get subfolders in directory
scene_files = for d in dirArray collect (trimright (filenameFromPath d) "\\")
print scene_files
sort scene_files
xreffilepather= "G:\\" + oReadline + "\\C_MASTER_FILES\\02_XREFS\\*.max"
xref_files = getFiles xreffilepather
sort xref_files
--Destroy Menu
if ((menuMan.findMenu "ADC Manager") != undefined) then
menuMan.unRegisterMenu (menuMan.findMenu "ADC Manager")
menuMan.updateMenuBar()
--Menu
--create a Menu to add onto the main menu bar
newMenu = menuMan.createMenu "ADC Manager"
--create a SubMenu menu 1
scenesubMenu = menuMan.createMenu "Scene"
ii = 0
for i in scene_files do
ii = ii + 1
bobby = scenefilepather + i + "\\02_3D\\"
execute str
MenuItemone = menuMan.createActionItem ("smartmenu_scene" + (ii as string)) "smartmenu_scene"
scenesubMenu.addItem MenuItemone -1
--create a SubMenu menu 2
xrefsubMenu = menuMan.createMenu "Xref"
ii = 0
for i in xref_files do
ii = ii + 1
str = "macroscript smartmenu_xref" + (ii as string) + " category:\"smartmenu_xref\" buttontext:\"" + (getFilenameFile i) + "\" (loadMaxFile \"" + i + "\")"
execute str
MenuItemtwo = menuMan.createActionItem ("smartmenu_xref" + (ii as string)) "smartmenu_xref"
xrefsubMenu.addItem MenuItemtwo -1
--create a Menu Item holding that menu
subMenuItemscene = menuMan.createSubMenuItem "Scene" scenesubMenu
subMenuItemxref = menuMan.createSubMenuItem "Xref" xrefsubMenu
--add it to our new menu in the 1st position
newMenu.addItem subMenuItemscene 1
newMenu.addItem subMenuItemxref 2
--get the Main Menu
mainMenu = menuMan.getMainMenuBar()
--find last item + 1
menuPos = mainMenu.numItems() + 1
--create a Menu Item for the new menu
newMenuItem = menuMan.createSubMenuItem "ADC Manager" newMenu
--add it to the main menu
mainMenu.addItem newMenuItem menuPos
--update the main menu to reflect the changes
Anyone got any ideas why it won't drill down a folder?
I don't have max to test, but try with this:
