Normal map Baking
By Goonda · 2012-09-12
I have been trying to write something which will bake the Normal map from a high_poly model to a Low_poly model....but the problem is nothing is getting rendered. Although all the parameters are applied as i can see in the max file....the projection modifier, cage settings, Highpoly picked....also I can see that it is rendering the normal map.....only thing is it is coming blank!! Can anyone find the problem please??
		global thehighSS = "select the highpoly mesh"
		global thelowSS = "select the low poly mesh"
		global thePathSS = "C:\\"
		rollout nm "Normal_Map" width:194 height:424
			pickbutton btn_high "High_Poly" pos:[60,24] width:68 height:20
			label lbl_high "select the highpoly mesh" pos:[26,50] width:135 height:17
			pickbutton btn_low "Low_Poly" pos:[59,76] width:72 height:21
			label lbl_low "select the low poly mesh" pos:[25,103] width:144 height:20
			GroupBox grp1 "Select Meshes" pos:[8,8] width:176 height:119
			button btn_path "Select Path" pos:[56,165] width:80 height:32
			label lbl_path "C:\\" pos:[16,203] width:160 height:16
			GroupBox grp2 "Path" pos:[8,153] width:176 height:72
			dropdownList ddl_dimension "Dimension" pos:[13,235] width:171 height:40 items:#("32", "64", "128", "256", "512", "1024", "2048", "4096")
			radiobuttons qualrad "" pos:[29,305] width:118 height:32 labels:#("low", "medium", "high", "best") columns:2
			GroupBox grp3 "Quality" pos:[9,283] width:175 height:64
			checkbox chk_auto " Auto Unwrap" pos:[37,133] width:120 height:16
			button btn_render "Render" pos:[44,383] width:101 height:29
			spinner spn_cagedist "" pos:[110,355] width:52 height:16 range:[-100,100,2]
			label lbl_cagedist "Cage Distance:" pos:[28,355] width:78 height:22
			on btn_high picked o do
				if superclassof o == geometryclass and classof o != bonegeometry then
					lbl_high.text = o.name
					select o
					global highpoly = o
					messagebox "Select a mesh" title: "Wrong Selection"  beep:true
			on btn_low picked obj do
				if superclassof obj == geometryclass and classof obj != bonegeometry then
					lbl_low.text = obj.name
					select obj
					global lowpoly = obj
			on btn_path pressed do
				thePathSS = getSavepath()
				if thePathSS != undefined then
						lbl_path.text = thePathSS
						messagebox "No path defined" title: "Path Not Defined"  beep:true
			on btn_render pressed do
			size = ddl_dimension.selected as integer
			cagedistance = spn_cagedist.value
			for o in geometry do
				if classof o != bonegeometry do
					o.material = undefined
					o.material = standardMaterial showInViewport:true
			converttopoly lowpoly
			theProj = ProjectionMod()
			addModifier lowpoly theProj
			theProj.addObjectNode highpoly
			theProj.autowrapCage()
			theProj.resetCage()
			theProj.pushCage cagedistance
			theProj.addRegisteredProjectionType 1
			theProj.projectProjectionType 1
			theProj.ignoreBackfacing = true
			lowpoly.iNodeBakeProperties.removeAllBakeElements()
			lowpoly.INodeBakeProperties.bakeEnabled = true
			lowpoly.INodeBakeProperties.bakeChannel = 1
			lowpoly.INodeBakeProperties.nDilations = 4
			be1 = NormalsMap()
			be1.outputSzX = be1.outputSzY = size
			be1.fileType = (thePathSS+"\\"+$.name+"_normal.png")
			be1.fileName = filenameFromPath be1.fileType
			be1.enabled = true
			be1.useNormalBump = true
			be1.targetMapSlotName = "diffuse"
			lowpoly.INodeBakeProperties.addBakeElement be1
			NormDiff = bitmaptexture filename:be1.fileType
			lowpoly.material = standardmaterial diffuseMap:NormDiff showInViewport:true
			render rendertype:#bakeSelected outputwidth:size outputheight:size
			completeRedraw()
		createDialog nm
Comments (7)
Op, Sory!
No Googlt_T, my bad.
I still wonder why all roman(latin) languages sometimes uses C as K.
Reply to miauu
I don't know why, but certainly not because Goonda lookig the best solution for Normal map Baking. :)
Anyway, "K" is better then "C" for our neighborhood.
Are you thinking about how to change your fitst(capital) name letter to "C", or i miss the point?
Hi, Branco!
Actually the RTTAssist uses the baking code from ToTex2. Just changed to work with othre tools in RTTAssist.
Google translate or you practice bulgarian langiage?
Reply to miauu
Hi neighbor,Google
Hi neighbor,
Google translate, of course. Both are the best tools for solving topic problem. You're the author of first one. Right?
Because of that RTTAssist is my #1 choice for sure.
By the way, when i change my name you'll first know but for now
is Branko :) I think that Google-T is to blame :)
Cheers friend!
Reply to miauu
Здрасти Костадин,
Мисля, че няма по-добър избор на две mxs-a. :)
поздрав!
Бранко
Reply to miauu
Goonda
Working Now
Thanks Miauu......Your script is too complex for me to understand.....still I just added one line from it, and it started working!! :)
macros.run "Render" "BakeDialog"
