newbie need help
By titane357 · 2008-09-19
Hello
as said : I'm a newbie.
My script : I want to move vertex of editpoly numerically :
But I have error : "impossible to convert spinnercontrol:deltax to float"
can somebody help ?
macroScript MOVEpts
category:"yoko"
toolTip:""
rollout MMove "Move"
spinner deltax "x: " type:#float range:[-1000,1000,0]
spinner deltay "y: " type:#float range:[-1000,1000,0]
spinner deltaz "z: " type:#float range:[-1000,1000,0]
button create "GO"
on create pressed do
objx = selection[1]
move objx.selectedVerts[deltax,deltay,deltaz]
createDialog MMove
martinskinner
Hi
Just looking through you're script quickly, and i've not tested this but;
the line:-
should read:-
move objx.selectedVerts[(deltax.value),(deltay.value),(deltaz.value)]
This should sort things out.
The float is the value of the spinner called deltax, not the variable deltax.
Hope that's sorted the problem.
Martin
www.martinskinner.co.uk
Reply to martinskinner
titane357
Thank you very much Martin for your quick answer !
Works fine now !
I do architectural visualisation too, and I'll try to add a lot of very little scripts to help modelling in Max.
Like aligning vertex,etc...
