Hi
I am trying to make a simple script to change a selected spline knot type. it goes as as follows:
drawing a rectangle and select a rectangle
and click a script button
convert a editable spline
and all vertex convert a "corner"
any help regarding this problem is also greatly appreciated,
Thanks!!!
Take a look this topic in mxshelp
http://docs.autodesk.com/3DSMAX/16/ENU/MAXScript-Help/index.html?url=fil…
This is your code
fn createRect length: width: =
node = converttosplineshape (Rectangle length:length width:width cornerRadius:0)
for k = 1 to numknots node do setKnotType node 1 k #corner
updateShape node
-- run this function with nex line. U can change width and length value also
createRect length:30 width:50
THANKS A LOT
wow... very simple and perfect...
I troubled by trying to make using a "changeKnotTypes" & "setKnotType"
Thanks, barigazy
