Hi, I'm currently trying to develop some custom tools for a project I'm working on.
I've currently got a rollout featuring a dropdownlist (ddlObjects) and a button (btnMove), among other things.
ddlObjects contains the names of several scene objects, either poly meshes or splines. These names are stored in the ddlObjects.items array as strings.
What I want is for btnMove to move whatever object is selected in ddlObjects by a set amount. Preferably without the object being visibly selected in a viewport.
Currently I'm been trying
move ddlObjects.selected [0,1,0]
or other variation there of, but am stuck on the problem of the selection from ddlObjects being read as a string.
I know that this is probably a simple thing to fix but I can't for the life of me find out how. Please advise.
Execute is bad way to do... you can use getNodeByName() function, ie:
Thanks for the info. I'll try your way.
Could you explain why execute is a bad way to do it? I'd like to know.
Ok, "execute" borrowed by
Ok, "execute" is borrow from pure C and has very slow runtime performance.
you can try command 'execute'
something like this: FF = execute("Spehere01") which will be understood as FF = Spere01
not sure if this is "correct" way to do scripts but works for me.
This seems useful but doesn't seem to work in this case. I'm trying it like this:
target = execute(ddlObjects.selected)
move target [0,1,0]
But keep getting this error:
-- No ""move"" function for undefined
I am, of course, making sure that there is items in the list and that they are selected.
Problems solved. Found the sulution in 3ds Max's FAQ/
It seems I just needed to expand the string for the execute command. My new code looks like this:
target = execute("$" + lbxObj.selected + "'")
move target [0,1,0]
It now works gloriously thank you for your help.
