hello, i am working on project that transferring data from micro-controller
using serial port to effect object in 3Ds max
ex.
0.75,0.60,5.03
0.62,1.34,9.36
0.50,2.06,13.07
0.38,2.75,15.60
0.26,3.41,17.73
0.16,4.06,19.51
and i have researched alot to find some maxscript similer to my project and i found this :-
port = dotNetObject "System.IO.Ports.SerialPort" "COM3" 115200
port.parity = port.parity.none
port.databits = 8
port.stopbits = port.stopbits.one
port.handshake= port.handshake.RequestToSend
rollout MinImu "MinImuToMax" width:90 height:150
dotNetControl dn_labelPR "System.Windows.Forms.Label" text:"seconds" pos:[20,10] width:50 height:20
dotNetControl textboxctrl "System.Windows.Forms.TextBox" pos:[20,30] width:50 height:30
button Frames "Frames" width:50 height:20
button Start "Start" width:50 height:20
button Stop "Stop" width:50 height:20
on Frames pressed do
finSec = textboxctrl.text as integer
finFrame = finSec * 25
animationRange = interval 0 finFrame
on Start pressed do --the button
port.Open()
finSec2 = textboxctrl.text as integer
finFrame2 = finSec2 * 25
for i= 1 to finFrame2 do
rotValue = port.ReadLine() as string
--encontramos las letras
r = findstring rotValue "r"
p = findstring rotValue "p"
y = findstring rotValue "y"
en = findstring rotValue "e"
--las convertimos en numeros float
r2 = r as float
p2 = p as float
y2 = y as float
en2 = en as float
--asignamos limites del substring
r3 = r2 + 1
p3 = p2 - 2
p4 = p2 + 1
y3 = y2 - p4
y4 = y2 + 1
en3 = en2 - y4
--aislamos roll pitch yaw
roll = substring rotValue r3 p3
pitch = substring rotValue p4 y3
yaw = substring rotValue y4 en3
--convertimos roll pitch yaw en numeros float
rollValue = roll as float
pitchValue = pitch as float
yawValue = yaw as float
--imprimimos roll pitch yaw
--print rollValue
--print pitchValue
--print yawValue
--enviamos valores a la caja
if rollValue != undefined then
$caja.rotation.controller.x_rotation = rollValue
if pitchValue != undefined then
$caja.rotation.controller.y_rotation = pitchValue *-1
if yawValue != undefined then
$caja.rotation.controller.z_rotation = yawValue *-1
completeRedraw()
sliderTime += 1
on Stop pressed do
port.Close()
createdialog MinImu
what i understood from that code, is that maxscript opens the port to receive data (COM3 for ex.) and then it searches for the line with r and read the coordinates to affect the object named caja
but the problem is that i always facing this message
" -- Unable to convert: undefined to type: Float "
i hope to find help here, i am a beginner at MaxScript
Regards,
Hisham ..
I don't know if this can solve your problem
local port = dotNetObject "System.IO.Ports.SerialPort" "COM3" 115200
port.databits = 8
try(destroyDialog ::MinImu)catch()
on Frames pressed do if textboxctrl.text != "" do
port.Open()
r2 = r as float
p2 = p as float
y2 = y as float
en2 = en as float
r3 = r2 + 1
p3 = p2 - 2
p4 = p2 + 1
y3 = y2 - p4
y4 = y2 + 1
en3 = en2 - y4
--print rollValue
--print pitchValue
--print yawValue
if rollValue != undefined do $caja.rotation.controller.x_rotation = rollValue
if pitchValue != undefined do $caja.rotation.controller.y_rotation = pitchValue *-1
if yawValue != undefined do $caja.rotation.controller.z_rotation = yawValue *-1
completeRedraw() ; sliderTime += 1
on Stop pressed do (port.Close())
createdialog MinImu 90 150 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow) ; ok
