Need some help with sweep modifier properties
By camilo perez · 2011-11-27
Hi, I'm a noob in the MAXscript world, I'm tring to write a scipt that allows me to read some coordinates form a text file whith which I want to draw "fibers" using splines and then using a sweep modifier with a cylinder section, all these thing I could do easy, but when I try to change the radius of the cylinder_section, there is nothing I can do to accomplish it. I've tried:
addmodifier $fiber1 (sweep()) -- fiber1 is a spline
$fiber1.sweep.currentbuiltinshape = 4 -- 4 refers to a cylinder section $fiber1.sweep.cylinder_section.radius = 10 --
But it returns unknown property "cylinder_section" in sweep:Sweep and also tried
mn = sweep()
addmodifier $fiber* mn
mn.currentbuiltinshape = 4
mn[4].radius =10
it doesn't work either, returns unkown property "radius" in undefined.
The weird thing is that when I input this code in the listener it works, but when I run the script it doesn't work.
thanks in advance
LittleLordPotala
Another idea...
I don't have this error message on Max 2012 64bits sp2.
I'm not sure but I think this error can sometimes occur if Maxscript attempts to call a property that is "not yet" loaded. In that particular case, Maxscript has to wait for this property.
An easy way to verify it, is to execute the script step by step in the Maxscript listener.
Another question would be : when you apply manually the sweep modifier with a circle shape, can you access the radius property in Maxscript listener ?
(For this, just select your spline with the sweep mod and type in the command : $.modifiers["sweep"][4].radius)
If you cannot access this property, you have a bug and the solution is probably to reinstall Max...
If it works, then you can try the following code :
obj = $
sweepMod = sweep()
addmodifier obj sweepMod
when parameters obj change id:#paramChange handleAt:#redrawViews do
	sweepMod[4].radius = 5
	deleteAllChangeHandlers id:#paramChange
sweepMod.currentbuiltinshape = 4
redrawViews()
If it still doesn't work, you can also use callback events (see the Maxscript documentation for "callbacks.addScript").
Hope it helps. Best regards.
LittleLordPotala
The solution :
--To create instanced modifiers :
obj = $fiber* --and if you select objects -> obj = $selection
addmodifier obj (sweep())
obj[1].modifiers["sweep"].currentbuiltinshape = 4
obj[1].modifiers["sweep"][4].radius = 3
--And an option to make it unique, only if needed :
mdf = for i in obj collect i.modifiers["sweep"]
InstanceMgr.MakeModifiersUnique obj mdf #individual
But if you only need to create cylinders with spline,
you don't need a script, you can use in the modify panel
editable spline -> rendering -> "enable in renderer" + "enable in viewport"
and change the radial parameters as you like.
And each new spline you create will automatically have this parameters.*/
--Of course, you can change the spline parameters with a script :
obj = $fiber*
for i in obj do
obj.render_renderable = true
obj.render_displayRenderMesh = true
obj.render_thickness = 5
obj.render_sides = 12
Reply to LittleLordPotala
Wassim Jabi
Still does not work
I am facing the same problem as the original poster. I followed the example in the AutoDesk Maxscript tutorial. I have the following script (mySplineShape is a spline shape I have pre-created):
sweepMod = sweep()
addmodifier mySplineShape sweepMod
It applies the sweep modifier with a circle, but then I immediately get the dialog box:
-- Unknown property: "radius" in undefined
And indeed sweepMod[4] is undefined. While sweepMod[1] sweepMod[2] and sweepMod[3] are defined.
I tried the script solution above as such:
addmodifier mySplineShape (sweep())
mySplineShape.modifiers["sweep"].currentbuiltinshape = 4
mySplineShape.modifiers["sweep"][4].radius = 5
but I still get the exact same error.
Reply to Wassim Jabi
Wassim Jabi
Finally found the solution!
I finally found the solution on another forum: http://forums.cgsociety.org/archive/index.php?t-654208.html
Basically, you need to update the stack. You could do this by inserting either a redrawViews or simply asking for the classOf aShape.
theMod = sweep()
theShape = Circle radius:100
addModifier theShape theMod
classOf theShape
theMod[4].radius = 50
