Hello:)
Im writing to ask about a problem I seems can't figure out....
I have a small script to make turntable ... you can find it here
http://www.scriptspot.com/3ds-max/scripts/hoha-superiorturntable-camera
It works as I expected. What it does is that it make the splines, create camera, make path constrain to the splines, and animation of weight and percentage.
The problem here is, when I save the file, and open it again... most of the path added disappeared... Means, if there are 5 paths added to path constrain, when I reopen the file, there is only 1 left.... I do not know how it happen, and why....
Please if you are so kind, can you have a look at the script and the problem, and see what is wrong with it... I think it is because of the script. Since I try to do the samething manually, then it save properly...
Can't understand What I did wrongly... It is irritating a lot...
Thanks a lot.
Comments (8)
Well it does now... Something is really wrong with my computer... or my head...
Thanks Budi G!
Without this " pc.path = Array_Circle[1]" it doesn't run properly.
I'm tryting to figure a way around...
Hi superhoha ...After
Hi superhoha ...
After removing "pc.path = Array_Circle [1]",
did you change a looping command ?
as I said earlier, such as :
If you are still confused, I upload your scripts.
I edited your code a bit.
this script has been working properly to me
@Barigazy
:) I just test your code :) seems it doesn't run properly. :(
Thanks A LOT !!!!!
@ Budi G : Thank you a lot!!!! It is wierd it happend bc of that.... We don't know why? ... Anyway really thanks a lot for figure that out...
@Barizagy: Thanks for your work on my code :) I will put your name there ^^
I have some questions to ask thought:
1./ I dont really understand this...:
pc = TurnCamStandard[3][1].track = Path_Constraint()
Can you explain to me?
2./ What is the difference between "undo on" and "with undo on" ?
Thanks a bunch Bazigary :)
1)At the same time I assign controller to camera and place it in "pc" variable
http://www.scriptspot.com/forums/3ds-max/general-scripting/copy-and-past…
2) is the same
There is something wrong in 'pc.path ()' function, I don't know how..
a snipet from your scripts:
Try to remove this, it's make some bugs or something
then try to make a normal looping
such as :
Yup. Budi G is right.
I organized your code a bit.
Also U can use CustAttribute to store all nodes of Path Constraint, attached on same constraint. Then you can make a fn to restore all nodes ei. targets back.
