Need help setting up radio button
By Andrew · 2014-04-17
I'm very new to scripting and stumbling at the basics. I followed a script tutorial from Louis Marcoux on how to animate the construction of a building. It's a simple script that rotations and unhides an object or multiple objects and added keyframes.
The problem I have is a want to link it up to a dialog box and control the timing and the direction of rotation. I've made it control the timing but I have no idea how to implement a radio button to control the x,y,z rotation axis.
Also since creating this as a microscript I've lost the abitlity to undo after running the script. It was fine when it was just a standard script, I could undo the keyframes applied but now it doesn't. Is this something to do with it being a microscript?
This is what I have so far and thank you for your help.
brttd
Just use something like this:
on BTN_CreateAnimation pressed do
   TheStartFrame = SPN_TheStartFrame.value
   TheEndFrame = SPN_TheEndFrame.value
   AnimationSegment = 5.0
   OffsetAnimation = ((TheEndFrame-AnimationSegment)-TheStartFrame)/Selection.count
   TheCurrentFrame = TheStartFrame
   case rdo_AxisRotation.state of
      1:(
         --X rotation
         for a in Selection do
            with animate on
               at time (TheCurrentFrame+5.0) in coordsys local a.rotation.x = 0.0 --change rotation axis here
	       at time (TheCurrentFrame +1.0) a.visibility.controller.value = 1.0
	       at time TheCurrentFrame in coordsys local a.rotation.x = degtorad (-120.0) --change rotation axis here
	       at time (TheCurrentFrame +0.0) a.visibility.controller.value = 0.0
             TheCurrentFrame = TheCurrentFrame + OffsetAnimation
      2:(
         --Y rotation
         --Copy and modify animation code
      3:(
         --Z rotation
Hope this helps.
Reply to brttd
Andrew
Works like a charm
Thank you so much for this, works like a charm. Never thought about states. I was trying to set it up to substitute the value x,y or z but couldn't get it to work. Still having trouble with the undo function, but I can live without it as long as I save before hand.
Thanks again
