Need help replacing some maps in my scene.
By nacho008 · 2015-01-28
Hi I'm a new at using MAXScript, and I need to replace a lot of Normal Bump maps in my scene. I imported some models and they have a Multimaterial with several VrayMtl on them, and in some of those VrayMtls there is a Normal Bump map which I need to replace with a VrayNormalMap with the same Bitmap as before.
I searched the forums and someone had a similar problem (actually was the exact opposite), and I found a script that replaces VrayNormalMap with a Normal Bump map, so I tryed to tweak it to do the inverse, but I can't seem to make it work. I believe I need to specify that it is inside a multimaterial, and then a VrayMtl submaterial, but now I'm totally lost.
Any help would be really aprecciated.
This is the script I found earlier from barigazy:
try(destroydialog ::vrnRoll) catch()
rollout vrnRoll " VrayNormalMap Convertor" width:168 height:30
	fn filterNMap obj =
		isKindOf obj.material VRayMtl and \
		isKindOf obj.material.texmap_bump VRayNormalMap and \
		isKindOf obj.material.texmap_bump.normal_map Bitmaptex and \
		obj.material.texmap_bump.normal_map.filename != undefined
	button btn "VrayNormalMap to NormalMap"
	on btn pressed do
		if (getClassInstances VRayNormalMap).count != 0 do
			local objMtlsArr = for g in geometry where filterNMap g collect g.material
			if objMtlsArr.count != 0 do
				for m in objMtlsArr do
					local NMap = Normal_Bump name:(m.texmap_bump.name) normal_map:(m.texmap_bump.normal_map)
					m.texmap_bump = NMap
				free objMtlsArr
createDialog vrnRoll style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Comments (9)
Tornado Mango
VrayLighrMtl Material to VrayMtl Material
Hello,
I would be appreciated if someone help me to make the script above to convert VrayLighrMtl Material to VrayMtl Material.
Pleaaaaase!
tomastnt
Would be possible change also a Gamma to 1.0?
Hi!
Its great script! Might you know there is a bug with Vray and normal bump in proxy objects. So all proxy objects has to have material with vraynormalmap, not with normalbump and this script is a solution.
I would be very pleased to have also an option to load every bitmap in converted vraynormalmap with gamma 1.0 in 3DS Max 2010 :) Pleasssss :)
nacho008
Nevermind, I found the error, a couple of materials had no bitmap assigned to the Normal Bump, thats where it crashed.
In any other case it works perfectly! Thanks again barigazy!!
Reply to nacho008
Try this
rollout vrnRoll "NormalMap Convertor" width:168 height:30
button btn "NormalMap to VrayNormalMap"
fn getMaterial arr = for i in arr where isKindOf i VRayMtl collect i
on btn pressed do
for g in geometry where g.mat != undefined and (ins = getClassInstances Normal_Bump target:g.mat).count != 0 do
for m in ins where (isKindOf m.Normal_map Bitmaptex) do
NMap = VRayNormalMap name:(m.name) normal_map:(m.Normal_map)
if (arr = getMaterial (refs.dependents m.Normal_map)).count > 0 do (for n in arr do n.texmap_bump = NMap)
nacho008
Yeah, I tried that same thing, but it doesn't work. It returns a dialog that reads:
MaxScript Rollout Handler Exception
--No "map" function for undefined.
On the Listener it reads the following:
Rollout:vrnRoll
true
-- Error occurred in getMaterial(); filename: ; position: 213; line: 5
--  Frame:
--   arr: undefined
--   called in m loop; filename: ; position: 554; line: 14
--  Frame:
--   arr: undefined
--   m: Map #443:Normal Bump
--   NMap: Map #443:VRayNormalMap
--   called in g loop; filename: ; position: 614; line: 15
--  Frame:
--   ins: #(Map #443:Normal Bump, Map #45:Normal Bump)
--   g: $VRayProxy_AM_133_building_003_001_hi
--   called in btn.pressed(); filename: ; position: 619; line: 16
--  Frame:
>> MAXScript Rollout Handler Exception:
-- No "map" function for undefined <<
OK
Rollout:vrnRoll
true
--  Frame:
--   arr: undefined
--  Frame:
--   arr: undefined
--  Frame:
--  Frame:
on btn pressed do
for m in ins do
if isKindOf m.Normal_map Bitmaptex do NMap.normal_map = m.Normal_map
nacho008
Thanks barigazy!! but your script does the opposite of what I want, it replaces any VrayNormalMap with a Normal Bump.
I need every Normal Bump replaced with a VrayNormalMap.
on btn pressed do
for g in geometry where g.mat != undefined and (ins = getClassInstances VRayNormalMap target:g.mat).count != 0 do
for m in ins do
NMap = Normal_Bump name:(m.name)
