need help
By AxAurum · 2016-12-22
Hi guys
how can I remove the segment from the shape through the maxscript
please help..
	--	"the index of the segment that you want to delete"
	segIdxTodel = #(3)
	subSplineIdx = 1
	splineObj = $Line001
	select splineObj
	max modify mode
	subobjectlevel = 2
	setSegSelection splineObj subSplineIdx segIdxTodel
	updateShape splineObj
	max delete
Reply to miauu
AxAurum
Thank you miauu
you just saved me!!!
if you can tell me why my method does not work
setSegSelection $ 1 #(3)
subobjectLevel = 2
splineOps.delete $
subobjectLevel = 0
updateShape $
Reply to AxAurum
I don't know.
But this works:
        setSegSelection $ 1 #(4)
	subobjectLevel = 2
	splineOps.delete $
	subobjectLevel = 0
	updateShape $
As you can see if the code is executed without brackets(everytnig is in global scope) the segment will be deleted. If the splineOps.delete is inside brackets(local scope) it not works.
Reply to miauu
AxAurum
Yes, I know that without the brackets everything works fine
but I need to create a function
In any case, your method works really well
I just replaced the "splineOps.delete" in "max delete" and got what I need
Thank you so much you helped me a lot
Happy new year!
cheers!!
