guys urgently need a script to remove comments from a script
can't find anything like it
any ideas??
need help!!!
By Steve Partridge · 2016-09-17
any ideas??
what kind of comment , is it /*..*/ or is it "-- line comment" ?
Hi fajar i have many line comments "--"
the problem is that these comments are at the end of lines
I have no idea how to remove them
use Notepad++. Open the script and remove all lines that starts with --. Then manually remove the /* */ comments.
thank you but this method is not suitable because the comments are at the end of lines
hey
this is only quick script to remove comments on end of line when they start with --
but if double dash is in string rest of line will be removed too
to detect strings and comments with /* */ in script is more difficult
try if this simple answer works for you
