Need help...
By illincrux · 2015-01-11
Greetings,
I'm having trouble running the script below in the student version of Max2015:
"1615134720"
"Bone Start @ 0xa0000080L"
-- Error occurred in readBElong(); filename: D:\Utilities\temp\Demon's_Souls\Demon's_Souls.ms; position: 433; line: 11
--  Frame:
--   fstream: <BinStream:D:\Documents\Projects\Lord\HD_F_9710.flver>
--   called in a loop; filename: D:\Utilities\temp\Demon's_Souls\Demon's_Souls.ms; position: 2355; line: 98
--  Frame:
--   BPos: 2684354700L
--   BoneNameOff: undefined
--   BoneName: undefined
--   a: 1
-- Error occurred during fileIn in "D:\Utilities\temp\Demon's_Souls\Demon's_Souls.ms"; line number: 11
>> MAXScript FileIn Exception:
-- Unable to convert: undefined to type: Integer64 <<
Script:
if (heapSize < 200000) then
        heapSize = 2000000 -- allow ~ 40 MB instead of just 7.5 MB. Prevents "Runtime Error: Out of scripter memory"
fname = getOpenFileName \
caption:"Open .flver from Mesh folder" \
types:"Demon's Souls (*.flver)|*.flver" \
historyCategory:"DemonsSoulsSObjectPresets"
f = fopen fname "rb"
clearlistener()
fn readBElong fstream = (bit.swapBytes (bit.swapBytes (readlong fstream #unsigned) 1 4) 2 3)
fn ReadBEshort fstream = (
return (bit.swapBytes (readshort fstream #unsigned) 1 2)
fn readBEword fstream = (
short = readshort fstream #unsigned
short = bit.swapBytes short 1 2
return short
fn readBEfloat fstream = (bit.intAsFloat (bit.swapBytes (bit.swapBytes (readlong fstream #unsigned) 1 4) 2 3))
fn ReadBEHalfFloat fstream =
	hf=readBEword fstream
	sign = bit.get hf 16
	exponent = (bit.shift (bit.and hf (bit.hexasint "7C00")) -10) as integer - 16
	fraction = bit.and hf (bit.hexasint "03FF")
	if sign==true then sign = 1 else sign = 0
	exponentF = exponent + 127
	outputAsFloat = bit.or (bit.or (bit.shift fraction 13) \
	(bit.shift exponentF 23)) (bit.shift sign 31)
	return bit.intasfloat outputasfloat*2
fn readFixedString bstream fixedLen = (
local str = ""
for i = 1 to fixedLen do (
str += bit.intAsChar (ReadByte bstream #unsigned))
str
struct weight_data
	boneids,weights
struct Mesh_Info_Struct
VertexCount, FaceCount, VertexSize, VertexOffset, VertSecSize, FaceOffset, FaceSecSize
clearlistener()
fseek f 0x6 #seek_set
Endian = ReadByte f
Unk=ReadByte f
type1=ReadBEword f
type2=ReadBEword f
dataOffset = readBElong f
print (dataOffset as string)
dataSize = readBElong f
count = readBElong f
numMat = readBElong f
BoneCount = readBElong f
numParts = readBElong f
numMesh = readBElong f
fseek f 0x80  #seek_set
for a = 1 to count  do (
getPos = ftell f + 64
fseek f getPos #seek_set
for a = 1 to numMat do (
getPos = ftell f + 32
Print ("Bone Start @ 0x"+((bit.intAsHex(ftell f))as string))
BNArr = #()
Mesh_Info = #()
Bone_Names_Array = #()
Trans_array = #()
Rotation_array = #()
Scale_array = #()
BoneMapCount = 29
BonePos=ftell f
for a = 1 to BoneCount do (
fseek f 0xC #seek_cur
BPos=ftell f
BoneNameOff = ReadBElong f
fseek f BoneNameOff #seek_set
BoneName=readFixedString f 20
fseek f BPos #seek_set
fseek f 0x74 #seek_cur
append Bone_Names_Array BoneName
fseek f BonePos #seek_set
  BONEarray = #()
   getPos = ftell f + 128
   px = readBEFloat f
   py = readBEFloat f
   pz = readBEFloat f
   BONEposition = [px,py,pz]
   ofsBONEname = readBElong f
   rx = readBEFloat f ; ry = readBEFloat f ; rz = readBEFloat f
   BoneRotation = ((eulerAngles (RadToDeg (rx)) (RadToDeg (ry)) (RadToDeg (rz))) as quat)
   ParentID = readBEword f
   Unknown01 = readBEword f
   sx = readBEFloat f
   sy = readBEFloat f
   sz = readBEFloat f
   BONEscale = [sx,sy,sz]
   Unknown02 = readBEword f
   Unknown03 = readBEword f
   bne = dummy showLinks:true showLinksOnly:true
   bne.scale = BONEscale
   bne.rotation = conjugate BoneRotation
   bne.pos = BONEposition
   append BONEarray bne
   if ParentID!=(0xFFFF) then (
    bne.parent = BONEarray[(ParentID+1)]
    bne.transform *= bne.parent.transform
Print ("Bone End @ 0x"+((bit.intAsHex(ftell f))as string))
MeshInfo=ftell f
for a = 1 to numParts do (
LodId= readBElong f
FaceCount= readBElong f
VertexCount = readBElong f
for a = 1 to BoneMapCount do (
Bone_Map = ReadBEword f
Null = ReadBEword f
FaceSecSize= readBElong f
FaceOffset = readBElong f
VertSecSize = readBElong f
VertexOffset = readBElong f
VertexOffset2 = readBElong f
null2= readBElong f
null3= readBElong f
VertexSize = (VertSecSize/VertexCount )
append Mesh_Info (Mesh_Info_Struct VertexCount:VertexCount FaceCount:FaceCount VertexSize:VertexSize VertexOffset:VertexOffset VertSecSize:VertSecSize FaceOffset:FaceOffset FaceSecSize:FaceSecSize )
print Mesh_Info
Print ("Mesh Info End @ 0x"+((bit.intAsHex(ftell f))as string))
fseek f MeshInfo #seek_set
for i = 1 to numParts do (
vertArray = #()
Facearray = #()
UV_array = #()
Weight_array=#()
BoneMapArray = #()
BoneMapIds = ReadBEword f
if BoneMapIds!=(0xFFFF) then
append BoneMapArray (BoneMapIds+1)
fseek f 0x1E #seek_cur
print BoneMapArray
Print ("Bone Map End @ 0x"+((bit.intAsHex(ftell f))as string))
BoneMapEnd=ftell f
FaceOffset=(dataOffset+(Mesh_Info[i].FaceOffset))
fseek f (dataOffset+(Mesh_Info[i].FaceOffset)) #seek_set
Print ("Face Start @ 0x"+((bit.intAsHex(ftell f))as string))
StartDirection = 1
f1 = ((ReadBEshort f) + 1)
f2 = ((ReadBEshort f) + 1)
FaceDirection = StartDirection
while ((ftell f) < (FaceOffset + (Mesh_Info[i].FaceSecSize))) Do (
f3 = (ReadBEshort f)
if (f3==0xFFFF) then (
) else (
f3 += 1
FaceDirection *= -1
if (f1!=f2)AND(f2!=f3)AND(f3!=f1) then (
if FaceDirection > 0 then append Facearray [f1,f2,f3]
else append Facearray [f1,f3,f2]
f1 = f2
f2 = f3
VertOffset=(dataOffset+(Mesh_Info[i].VertexOffset))
fseek f (dataOffset+(Mesh_Info[i].VertexOffset))	#seek_set
Print ("Vertex Start @ 0x"+((bit.intAsHex(ftell f))as string))
if Mesh_Info[i].VertexSize==52 then
for x = 1 to Mesh_Info[i].VertexCount do (
getPos = ftell f + Mesh_Info[i].VertexSize
vx = readBEFloat f
vy = readBEFloat f
vz = readBEFloat f
bone1 = readbyte f #unsigned
bone2 = readbyte f #unsigned
bone3 = readbyte f #unsigned
bone4 = readbyte f #unsigned
weight1 = (ReadBEword f /32767.00)
weight2 = (ReadBEword f /32767.00)
weight3 = (ReadBEword f /32767.00)
weight4 = (ReadBEword f /32767.00)
fseek f 0x14 #seek_cur
tu=ReadBEfloat f
tv=ReadBEfloat f*-1
w = (weight_data boneids:#() weights:#())
maxweight = 0
if(weight1 != 0) then
   maxweight = maxweight + weight1
if(weight2 != 0) then
   maxweight = maxweight + weight2
if(weight3 != 0) then
   maxweight = maxweight + weight3
if(weight4 != 0) then
   maxweight = maxweight + weight4
if(maxweight != 0) then (
      if(weight1 != 0) then (
         w1 = weight1 as float
         append w.boneids (bone1 + 2)
         append w.weights (w1)
      if(weight2 != 0) then (
         w2 = weight2 as float
         append w.boneids (bone2 + 2)
         append w.weights (w2)
      if(weight3 != 0) then (
         w3 = weight3 as float
         append w.boneids (bone3 + 2)
         append w.weights (w3)
      if(weight4 != 0) then (
         w4 = weight4 as float
         append w.boneids (bone4 + 2)
        append w.weights (w4)
append Weight_array w
append vertArray [vx,vy,vz]
append UV_array [tu,tv,0]
if Mesh_Info[i].VertexSize==40 then
vx = readBEFloat f
vy = readBEFloat f
vz = readBEFloat f
tu=ReadBEword f/1024.00
tv=(ReadBEword f/1024.00)*-1
maxweight = 0
if Mesh_Info[i].VertexSize==36 then
vx = readBEFloat f
vy = readBEFloat f
vz = readBEFloat f
fseek f 0x8 #seek_cur
maxweight = 0
if Mesh_Info[i].VertexSize==28 then
vx = readBEFloat f
vy = readBEFloat f
vz = readBEFloat f
weight1 = 1.00
maxweight = 0
fseek f BoneMapEnd #seek_set
try(
msh = mesh vertices:vertArray faces:faceArray
msh.numTVerts = UV_array.count
buildTVFaces msh
for j = 1 to UV_array.count do setTVert msh j UV_array[j]
for j = 1 to faceArray.count do setTVFace msh j faceArray[j]
msh.displayByLayer = false
msh.backfacecull = false
msh.wirecolor = (color 230 200 210)
max modify mode
select msh
skinMod = skin ()
addModifier msh skinMod
for i = 1 to BoneMapArray.Count do
	maxbone = BONEarray[(BoneMapArray[i])]
	if i != BoneMapArray.Count then
		skinOps.addBone skinMod maxbone 0
		skinOps.addBone skinMod maxbone 1
modPanel.setCurrentObject skinMod
for i = 1 to (Mesh_Info[i].VertexCount) do (
   w = Weight_array[i]
   bi = #() --bone index array
   wv = #() --weight value array
   for j = 1 to w.boneids.count do
      boneid = w.boneids[j]
      weight = w.weights[j]
      append bi boneid
      append wv weight
   skinOps.ReplaceVertexWeights skinMod i bi wv
)catch(format "failed!!\n")
fclose f
Test file is in the attachment.
Any help is greatly appreciated!
