hi
i opened .mzp file mistakenly in notepad as default program for opening mzp files now when i drop it in viewport it is not working
please help
pics are attached
thanks
viki
By vikirecon · 2017-09-24
hi
please help
pics are attached
thanks
viki
I think you're trying to drag and drop mzp.run file into viewport. You should drop *.mzp file instead.
Try to step back from mzp (zip file) and drag and drop N3D_ViewportSwitch_0.mzp
Best,
Pixamoon
@ pixamoon :)
hi Pixamoon
i am honoured for getting your attention(thanks for All your scripts :) )
if i understand you correctly you are saying that there is a file named N3D_ViewportSwitch_0.mzp and i have to dropt it in viewport but there is no file of that name or any file for example filename.mzp
i have attached another pic and script name is (Display as box) and it has mzp file name
thanks
regards
viki
hey, you're welcome :)
As far I know mzp.run is a startup file of .mzp file (Zip-file Script Package) - kind of autorun. I'm not sure if mzp.run can be dropped alone to max vieport from folder.
Did this script come in .mzp file or just zip/rar file ?
I'm attaching also sample .mzp file. You can just download it - open folder where is downloaded and drag and drop test.mzp to max vieport - Please do not unzip it to other folder just drag and drop test.mzp file
You can also try to compress all files from your folder to zip file and rename extension from .zip to .mzp And then drop it to max viewport.
Best,
Open the second image - press the CHANGE button in the Properties dialog and choose your archiv program(I use 7-zip).
You are Helping a Noob (warning) :)
hi miauu
thanks for responding
i did what you wrote but it i think i failed somewhere
it didnt work :(
can u put a youtube or pics for that
sorry for troubling you so much
thanks
regards viki
NOTE:- i used 7-Zip
