Modifier Property as Variable
By zpeletz · 2020-04-28
Hello. I am trying to figure out how to change a modifier property by using a variable. For example:
if x == 1 then
property = "moveX"
else if x == 2 then
property = "moveY"
selection.unwrap_uvw.property (0.5)
The issue I'm running into is how to concatenate the property variable correctly.
Vojtech Cada
Use setProperty
In a general case with a regular property access, you'd use setProperty like this:
setProperty (modPanel.getCurrentObject()) propertyName 0.5
If you wanted to get a method by name and call that, you could instead use getProperty and invoke the returned method:
(getProperty (modPanel.getCurrentObject()) methodName) 0.5
