Hi. This one drives me nuts. After making a plugin, along with a macroscript, after Max restarts, the button is greyed out and its name is changed to "Missing: MyScrip". It seems that every time Max is restarted it forgets that I installed this script.
Here's the macroscript:
macroScript MyScript
category:"FT"
toolTip:"This script cures cancer!"
buttonText:"Press Me"
on execute do
filein @"$scripts\FT\MyScript.ms"
The other stuff: the macroscript is in "...enu\UI\usermacros" while the script itself is in "...Scripts\FT". I did once fixed that, my other script works, but I just can't replicate / remember what I did.
Any ideas?
$syntax is for zip-packs
The syntax
is for Zip-file script packages (used inside "mzp.run" file).
Use
, i.e.:
