Sign in
missing files
By tinnnpo · 2012-02-26
Hi! I have a problem to get the number of missing files in a single object here is my script
the problem is that this script append the path of the texture 2 time for exemple if there is 2 missing files it it say that there is 4 what I am doing wrong?
if I use #localonly flag it didn't show anything.
global missingfiles = #()
function get_names name FilesArray = append FilesArray name
enumerateFiles $Plane01 get_names missingfiles #missing
print missingfiles.count
thank you very much for your help :)
its a known bug of that function
Anubis · 2012-02-26
Nothing wrong in your code usage, this double result is a bug of
enumerateFiles
function, it return fine result only then there no last named (and optional) argument (like #missing, #localonly and so on). You can use
makeUniqueArray
after it to cleanup your array, or if just the
.count
is important you can devide the result by 2.
