Mirror Animation
By Eric · 2013-11-26
Hello!
I found a scrip here in scriptspot that mirrors animation keys. I don't thinks it's been updated in a while so I'm hoping someone can help me fix it.
First thing it gives me some errors. I would also like to change it to a script vs. a modifier stack so I don't have to break instances on objects and most importantly is I need a way to set the tangents to splines and add a negative value to them so it becomes a true mirror of keys.
If anyone can take a look at the script or point me to a script pack that has something similar I would greatly appreciate it!!
Thanks!
Eric
Mirror Animation Modifier 0.4 [2010.9-2011.2] by Anubis
New in v.0.4:
* deleting event added (restore orig. keys on deleting)
* clone event added (disable transforms on clone as copy)
Keep in mind that this plugin is still beta and very limited ;-)
plugin modifier MirrorAnimation name:"MirrorAnimation"
classID:#(0x789fc233, 0x271c57f0) version:0.4
local dep = #()
local axisStates = #(#(1),#(1,2),#(1,3),#(2),#(2,3),#(1,2,3),#(3),#(0))
fn mirrorAnim owner tm axis = ( -- axis
try (
for a in axis do (
local keys = #(), track = owner.transform.controller[tm].controller
local cls = classOf track
if cls == position_list or cls == rotation_list then
keys = track[1][a].keys else keys = track[a].keys
if keys.count > 0 do (for k in keys do k.value *= -1)
) catch (format "Exception:\n%\n" (getCurrentException()))
fn isEqualArrayParam ap1 ap2 = ( -- compare ArrayParameter
a1 = ap1 as array ; a2 = ap2 as array
a1 as string == a2 as string
parameters main rollout:params
posAxis type:#integer ui:rbPA default:8
rotAxis type:#integer ui:rbRA default:8
posIndex type:#intTab tabSize:1 tabSizeVariable:true
rotIndex type:#intTab tabSize:1 tabSizeVariable:true
on posAxis set idx do -- Position
if not isEqualArrayParam axisStates[idx] posIndex do (
dep = (refs.dependentNodes this)
if posIndex[1] != 0 do -- is there something to undo
for i in dep do (mirrorAnim i 1 posIndex) -- restore old
posIndex = axisStates[idx] -- set new
if idx != 8 do (for i in dep do (mirrorAnim i 1 posIndex)) -- mirror new
on rotAxis set idx do -- Rotation
if not isEqualArrayParam axisStates[idx] rotIndex do (
if rotIndex[1] != 0 do -- is there something to undo
for i in dep do (mirrorAnim i 2 rotIndex) -- restore old
rotIndex = axisStates[idx] -- set new
if idx != 8 do (for i in dep do (mirrorAnim i 2 rotIndex)) -- mirror new
rollout params "Parameters"
group "Position Axis"
radiobuttons rbPA columns:3 labels:#("X","XY","XZ","Y","YZ","XYZ","Z","OFF") align:#left
group "Rotation Axis"
radiobuttons rbRA columns:3 labels:#("X","XY","XZ","Y","YZ","XYZ","Z","OFF") align:#left
on clone orig do -- // TODO ...
this.posAxis = this.rotAxis = 8 -- atm just disable (but do nothing if clone as instance!)
--on deleted do () -- Useless (!) 'cause Max call it only on File New/Reset
on postCreate do -- so, FiX Deleting-event in onCrete handle via callbacks
callbacks.removeScripts id:#MirrorAnimationModDeleted
fn onDeleteMirrorAnimMod = (
me = (callbacks.notificationParam())[2] -- #(node, modifier)
if classOf me == MirrorAnimation do
me.posAxis = me.rotAxis = 8
callbacks.addScript #preModifierDeleted "onDeleteMirrorAnimMod()" id:#MirrorAnimationModDeleted
--// Last update: 2011.02.28
