I have this bound to a hotkey and when I run it 3 times windows makes a "no" sound on the third button press. But then it will run on the forth press?
I honestly have no idea what the issue is.
Any ideas? Any help would be very appreciated.
The script just jumps between the top modifier and either last edit poly mod or base modifier.
local BaseSwitchSOL
if classof (modpanel.getcurrentobject()) == Editable_Poly or classof (modpanel.getcurrentobject()) == Edit_Poly then
BaseSwitchSOL = subobjectlevel
modPanel.setCurrentObject $.modifiers[1]
try
modPanel.setCurrentObject $.editpoly
subobjectlevel = BaseSwitchSOL
catch
modPanel.setCurrentObject $.baseObject
if BaseSwitchSOL != undefined then
subobjectlevel = 0
Solved! Sorta...
Just figured out that the issue has something to do with my home setup. It works fine at work.
hotkey issue?
Much cleaner man thank you! However I am still having the previous issue. It works as a button perfectly but the moment I set it to a hotkey... max doesn't like it pressed 3 times in a row. :/ It works as long as I do something in the viewport in between each time I hit the hotkey... so strange.
Here is where I am at on the final. Code does what I want it to now just max is being stupid.
not sure is this...
but why not move BaseSwitchSOL out of IF scope?
as currently it may stay undefined inside ELSE.
Or even do something like...
