Sometimes I have the problem that the listener/maxscript doesn't work. It just doesn't respond anymore. Dont know why. When I restart max everything is back normal. Does anyone know how to reset the listener or something?
so this problem usually occurs right after the run loop, but is not always the case. In MAXScript another computer stopped working no more answers ... Once I have this problem again I'll post here ...
Comments (11)
Escape works!
presssing esc key works
this happens when you miss a paranthesis in the codeblock..
just evaluate ) and you're back in biz
indeed
that's it! thanks a lot
Bad executed code :).
Just press ESCAPE key. Sometime this will unblock listener.
Listener will print
hmm possible, will try it next time!
I will also try the next time
tks
I mean *escape key* in listener.:)
Show your problem. Bad code is always a reason why this is happening.
Ok. But be careful when you use "while" loops.
Sometimes i have same problem.
