maxscript exportFile always use the current settings if we use #noPrompt
By max2u · 2010-03-17
Greetings ,
i was making a plugin that uses he obj exporter from 3dsmax 2009 , the problem that i want to always export normals and always not flipping y/z axis ,is there a way in the script (ms file) to set theses parameters to the exporter,well i dicovered that we can use the class ObjExp in the script but it seems that it has no parameters to set or i just cant deal with it,
any hint will be great, and plz make it quick ^.^
ken
Use the FBX export settings file(s)
Yes, not a 'quick' answer.. but for the benefit of others I figured I would add some info: you can use the FBX export settings file to hold export settings for you. As such, you can use different settings /preferences files and point to the right one depending on what type of export you are currently doing.
Hope this helps!
