I’m trying to write a maxscript that will create a custom modifier. That modifier will point the normals of the applied object toward the center of a selected object. Here’s my code:
plugin modifier MyModifier
name:"My Modifier"
classID:#(0x12345678, 0x87654321)
parameters main rollout:params
pickedObject type:#node ui:pickedObjectButton
rollout params "My Modifier Parameters"
button pickedObjectButton "Pick Object" width:100 align:#center
on pickedObjectButton pressed do
pickedObject = pickObject prompt:"Select an object to use"
if pickedObject != undefined do update()
on preRender do
if (selection.count > 0) do
obj = selection[1]
convertToMesh obj
meshData = snapshotasmesh obj
verts = meshData.verts
faces = meshData.faces
normals = #()
for f in faces do
p1 = verts[f.x]
p2 = verts[f.y]
p3 = verts[f.z]
norm = normalize (cross (p2 - p1) (p3 - p1))
append normals norm
pickedPos = pickedObject.transform.row4
for i = 1 to normals.count do
face = getFace obj i
norm = normals[i]
center = (verts[face.x] + verts[face.y] + verts[face.z]) / 3.0
dir = normalize (pickedPos - center)
newNorm = normalize (norm + dir)
setFaceNormal obj i newNorm
update obj
This creates the modifier with a button to select an object in the scene, but when I try clicking on an object I get this:
– Error occurred in anonymous codeblock; filename: C:\Users\JSwanson\OneDrive - S-E-A\Desktop\New folder (3)\Maxscripts\Test.ms; position: 504; line: 18
– MAXScript Rollout Handler Exception:
– Argument count error: generic apply wanted 1, got 0
– MAXScript callstack:
– thread data: threadID:42636
– [stack level: 0]
– In pickedObjectButton.pressed(); filename: C:\Users\JSwanson\OneDrive - S-E-A\Desktop\New folder (3)\Maxscripts\Test.ms; position: 505; line: 18
– member of: Rollout:params
– Locals:
– Externals:
– params: Rollout:params
– pickedobject: PluginParameter:pickedobject : $Target_Sphere:TPhotometricLight001 @ [1.824579,67.816650,79.362770]
– owner: Rollout:params
– [stack level: 1]
– called from top-level
What am I doing wrong?
well thats normal because its not object , its object target which is kind of dummy object...maybe you could filter it out using.. where not (isKindof targetxxx (object class) ...may be it'll workout ...need the whole sample scene tho..
