Maxscript dotnet
By john · 2015-03-30
Hi Guys,
I'm working on a script which uses a dotnet form for the UI. One of the elements is a ListView. When trying to get it to select one of the items I get an error. I'm basing a lot of it around:
http://scriptattack.com/snippets/snippets.html
Although I have to call functions like this:
Does anyone have an idea why it fails?
John
Comments (12)
john
Works
That works great for me, for now. I might want the index number at some point but not for now. Thank-you.
John
Reply to john
pixamoon
index
Sure :) To get index of first selected item:
lv_objects.SelectedItems.item[0].index
One important thing: dotNet arrays index starts from 0 (not like maxscript from 1)
Best,
Pixamoon
Reply to pixamoon
john
You little beauty! Perfect.
While you seem to be a bit of a dotnet genius. Don't suppose you know how to fix the padding on a dotnet webpage? (its a test image)
John
Reply to john
pixamoon
no no, I just had the same problems recently for my scripts... :p
I've never used dotnet webpage, but I'll take a look. It's nice to learn new things :)
Best,
Pixamoon
Reply to pixamoon
pixamoon
but do you need browser or you just want to add image / logo from the web to your script ?
Reply to pixamoon
john
An picture box would do. But the url I have is very long for the image I want to download. The web browser doesn't have a problem with the length. Its just really annoying the padding thing!!
Reply to john
pixamoon
yes, I was thinking about download image and than use it.
Did you try download with dotnet ?
I tried a bit your browser code. Still no success to change padding but I tried
webbrowser_rollout.left = -15
webbrowser_rollout.top = -10
to move image left and up,
this is only temporary solution :(
Reply to pixamoon
pixamoon
download file
did you try this way to download:
url = "http://assets3.parliament.uk/iv/main-large//ImageVault/Images/id_7382/scope_0/ImageVaultHandler.aspx.jpg"
newFile = (getDir #temp) + "//" + "00_test.jpg"
fn DownloadFile url newFile = (
	wc=dotNetClass "System.Net.WebClient"
	sr=dotNetClass "System.IO.StreamReader"
	wcobj=(dotNetObject wc)
	stm=wcobj.DownloadFile url newFile
shellLaunch newFile ""
It works here with your test image.
Reply to pixamoon
john
Wow
That's perfect!! I can just download all the thumbnails to the local drive and then reference them from there. Thanks-you so much. My UI will look loads better now. And quicker!
John
pixamoon
select in ListView
Do you want to select by script one item/line of listView or get selected line/lines?
Like in http://www.scriptspot.com/3ds-max/scripts/bitmap-tracking-resizing
or http://www.scriptspot.com/3ds-max/scripts/library-track-relink
to get selecttion count:
lv_objects.selecteditems.count
to get first selected item:
lv_objects.SelectedItems.item[0].subitems.item[0].text
to select 1st on the list:
lv_objects.Items.item[0].selected = true
where lv_objects is dotnet ListView
Hope it helps
Pixamoon
