I'm sure I'm just using the wrong keyword to search and the answer is readily available, but how do I run:
Max unhide all
from a script and have it either not prompt about unhiding hidden layers, or feed it the answer no from the script? Everything I try #nopompt, with quiet true, either fails or does nothing.
thanks in advance.
Thanks but..
Hey guys, thanks for the replies, both commands do unhide all objects, unfortunately that includes unhiding hidden layers which I didn't really want. After some fiddling (I hate the layermanager functions) I came up with this:
for o in objects where o.ishidden do
if (LayerManager.getLayerfromname (o.layer.name)).ishidden == false then
o.ishidden = false
Which seems to unhide objects that aren't on hidden layers as required. Is there anything wrong with that script or something that would make it better, faster, w/e?
Thanks again.
Why not iterate over layers instead?
try this:
objects is a collection so you can simplify it to:
