I would use Notpad ++ for
modify some scripts that when using max I can not change. because running.
How can I configure Notepad ++ as MaxScript language.
you did so from the menu?
speech / language define
thank
By Waltez · 2016-12-03
thank
why is you can not change script because max is running ? is there any reason behind it , its not maxscript need to compiler like c lang to activate isn't it ?
http://www.scriptspot.com/3ds-max/scripts/notepad-mxs-language-definitio…
http://www.scriptspot.com/3ds-max/scripts/external-maxscript-ide
