Heya,
I am trying to batch render some max files using the camera inside the file, if there is one. Thats why I use
render camera:theCam outputFile:outFileto start the rendering (if previously a camera has been found) and
rendOutputFileName = outFile; max quick renderif no camera has been found.
"outFile" is a pathname like this:
"C:/Users/br0t/Desktop/test.jpg"Both render an image, which looks correct in the Frame Buffer, but the first method will save a plain black image. max quick render works correctly, but I dont know how to set a camera as the active viewport. Any ideas why render() fails?
Cheers
Its a Vray Frame buffer problem.
To stop from getting a black image all you have to do is turn on the split channels checkbox in the vray frame buffer section. I just finished writing a script that does exactly what you mentioned above. If you need some more information on it let me know and I can show you the code.
gimme da code :D
hi br0t
No visible reason, render() with camera argument works fine. You can try also render to:bitmap but here is as well a snippet code to set a camera to the active viewport.
p.s. - if you render to bitmap...
thanks Anubis, that is helpful!
I think my black image is a Vray problem, or more a problem with the vray frame buffer. If I turn it off, everything renders fine. Unfortunately I cannot do that by script, so I am now loading a renderpreset each time, that thas the vfb disabled.
Cheers
