Is it possible to change their position? ie. Material Editor or Render setup.
I've searched a little - couldn't find it in MaxScript reference and the only one I found dealt with 3dsmax.ini - but it requires rebooting Max.
Is there a way to access ie: MEdit.dialog.pos ?
=D
If I remember correctly the .ini is read every time the material editor or render panel are opened and not just at start up. This means you could use the .ini to "move" the dialogs.
will have to check that.
Nice to see you here too ;)
You are correct my good man :)
So I guess I'm pretty lucky this time :)
