Material to mxs
By JokerMartini · 2011-11-23
So I'm thinking about working on a script that will take the actively selected material in the material editor and convert it to maxscript.
The returned maxscript will then recreate that shader when exectued.
I however want to make it so the script itself will bypass anything images or texture maps. So it is only really controlling values and properties.
Does anyone know if anything out there is already created to do this? Otherwise I'm not going to mess around with it.
JokerMartini
Cool
Thanks Anubis I'll check it out
JokerMartini
A start
Here is the start.
Why does this bug out? It actually works for the first bit of it if you comment out some of the properties
mat = meditMaterials[1]
type = classof meditMaterials[1]
clearlistener()
format "%%\n" type " \\"
for p in getPropNames mat do
format "%:% " (substring (p as string) 1 -1) (getProperty mat p)
