material library import/export
By kilad · 2009-03-21
New forum topics are on pause. Signed-in members can reply to existing topics. Contact ScriptSpot if you need help.
I want to move my material library with the corresponding maps from one machine to another.
Is there a script that collects all maps assigned to your current library,
then saves them in a given folder and relinks maps to that folder? or something similar?
or am i missing something?
kilad
Ralf Bartsch
I think you allready have a .mat file.
You could use the resourse-collector.
UtilitiesTab -> more -> ResourceCollector.
Give it an output-path you have (or can make) on the second machine. Check "update Materials"-box to re-links all your maps to that location.
If that doesnt do the trick (or not 100%) you should try
UtilitiesTab -> more -> Bitmap/Photometric Paths
Here you can check "include liberaries", and edit the locations manualy.
I dont think you need a Script for that.
AH!! i have overlooked the "Include material library" 😆
the resource collector doesnt consider the mat library, just the scene like archive does.
thank you very much for a quick answer!
