Hi!
I have a performance problem when creating a simple brick wall and I wonder if you have any tips or advices for me? :)
I want to create a brick wall from a list of instances.
If I work with a fair amount of instances everything works like a charm. But if I increase my amount over ca. 500 objects it slows down drastically.
I already turned off undo and disabled scene redraw...
Thank you in advance! :)
PS: I am an absolutely beginner in maxscript :/ ...
fn UpdateWall =
disablesceneredraw()
setCommandPanelTaskMode mode:#modify
suspendEditing which:#modify
undo off
local x = 1
for i=1 to num_length.value by 1 do
start = timestamp()
for k=1 to num_height.value by 1 do
local randBrick = pickedObjects[(random 1 pickedObjects.count)] -- pick random "brick" from brick array
if x > wallContainer.count then wallContainer[x] = instance randBrick --instance new "bricks" when array grows
local brick = wallContainer[x]
brick.pos.x = (stair_offset.value * (k-1))
brick.pos.y = (padding_length.value * (i-1) + ((mod k 2) * rowOffset.value))
brick.pos.z = (padding_height.value * (k-1))
x += 1
end = timestamp()
format "iteration % took % seconds\n" i ((end-start)/1000.0)
for item in x to wallContainer.count do
delete wallContainer[x]
deleteItem wallContainer x
enablesceneredraw()
resumeEditing which:#modify
