Hello ... I am fairly new to scripting.
I am currently accessing Maxscripts commands I've collected via the (Utilities tab > Maxscript > Utilities drop-down option) method.
I would also like to access various MSE scripts I've come across through this method. I know I can access some of these scripts via the toolbar or do a drag and drop unto the viewport. However, since I already have a number of scripts I am accessing through this method ... I would like to have them accessible from there as well.
How would I go about assigning the launch of an MSE script to a button action?
For instance ... this is what I am using to execute a Purge Empty layers from the Maxscript Utilities drop-down field:
utility Del User Def Prop "Delete User Define Properties"
button btn1 "Delete User Defined Properties" pos:[25,19] width:180 height:25
label lbl1 "This script goes through all selected objects and strips away user define properties." pos:[23,57] width:200 height:70
on btn1 pressed do
setuserpropbuffer (getcurrentselection()) ""
messageBox "User Defined Properties have been cleared."
What would be the appropriate command to launch an MSE file for the "on btn1 pressed do()" section?
Thanks in advance.
fileIn
If you only want to do that, use fileIn:
Thank you!!
