Hi All
How to create a unique group of objects from multiple arrays?
This is an example of a known array of layers
layer1 = #("Sphere001","Sphere002","Sphere003")
layer2 = #("Box001","Box002","Box003")
layer3 = #("Tube001","Tube002","Tube003")
then I used the loop method like this with the results I wanted
ObjectGroup= #()
for i=1 to layer1.count do
for x=1 to layer2.count do
for y=1 to layer3.count do
groups = #(layer1[i], layer2[x], layer3[y])
ObjectGroup += #(groups)
format "Total Result: %\n" ObjectGroup.count
print ObjectGroup
which is a challenge and makes me stuck.
What if the array number of layers is not yet known and each layer has an unknown number of objects?
Can this be done using the recusive method? so how to make it?
Use join to join current array to the accumulator one. That's the direct reply to your question, but in the context of your question where you don't know the number of layers and their contents, it depends more on the way you collect those, to give a toy example with layers:
I say toy example as objs here would be the same as the global
collection.
