Macroscript not jumping to Object's baseobject (modpanel)
By cptSwing · 2017-09-14
Hey guys, after a lot of writing / testing / deleting, I seem to have arrived where I wanted to - a script which toggles a "jump" down to an objects lowest modifier, on a selection change, and when used in a toolbar with visual feedback whether this mode is active. When using my base-jump function on its own, it works fine.. in conjunction with the macro, nothing happens when active (despite my debug messages saying everything works). Does anybody have an idea what might be wrong?
(I'm no scripting wiz as is apparent - I'm rather sure it's to do with the callbacks somehow?)
Thanks in advance for any answers!
macroScript ModifierAutoSelectToggle
	category: "MyTools"
	toolTip: "Visualize AutoModSel Toggle"
	ModAutoSelectActive == true
	on isChecked return (ModAutoSelectActive)
	global ModAutoSelectNoUi
	function ModAutoSelectNoUi = (
		objSel = getCurrentSelection()
		if objSel.count == 1 do (
			max modify mode
			modPanel.setCurrentObject objSel[1].baseobject
			format "Stack of % jumped to % \n" objSel[1] objSel[1].baseobject
	on execute do (
		if ModAutoSelectActive == true then (
			ModAutoSelectActive = false
			format "ModAutoSelectActive set to: % \n" ModAutoSelectActive
			callBacks.removeScripts id:#ModAutoSelectNoUiCallback
			format "Callback removed \n"
		else (
			ModAutoSelectActive = true
			callbacks.addScript #selectionSetChanged "ModAutoSelectNoUi()" id:#ModAutoSelectNoUiCallback
			format "Callback added \n"
Panteleev Sergey
imagine that we want to go to the baseobject level to add some modifier to multiple instance nodes at once
we select these nodes
set baseobject as current level
modPanel.setCurrentObject selection[1].baseobject
buuut... we have a problem now. selection is changed to single node
here is another way
case selection.count of
	0 : ()
	1 : ( max modify mode; modPanel.setCurrentObject selection[1].baseobject )
	default:
		max modify mode
		base = makeUniqueArray (for s in selection collect s.baseobject)
		if base.count == 1 do ( -- only if all nodes share same baseobject
			while modPanel.getCurrentObject() != base[1] do
				max prev mod
mistyrian
First floor
I'm a script beginner too , the Script "Modifier auto-select" in the website is invalid in max 2019 . I feel depressed that no one answered your question . so I spent a few days to study some relative content .
I think the porblem may be on #selectionSetchanged , in this case selectionchanged is better , but I don't find it in General event callback Mechanism of MAXScript Help , so I use #modPanelObjPostChange instead Here is my script ,I only tested it a few times , There are may be some problems .
macroScript bms_toggle
category:"All MyScripts"
tooltip:"bms toggle"
buttontext:"bms toggle"
global bms
function bms =
if selection.count==1 then (
callbacks.removeScripts #modPanelObjPostChange id:#bms
max modify mode
modPanel.setCurrentObject $ -- open on base object
callbacks.addScript #modPanelObjPostChange "bms()" id:#bms
print "empty selection"
cb = false
on execute do
if cb then
print "callbacks removed"
cb=false
cb = true
on isChecked do cb
Reply to mistyrian
mistyrian
another one
this one is very simple and original ,My knowledge are very limited. it is a very low-end approach.but it works better
