Hello,
I'm trying to do like in this picture : http://imageshack.us/a/img855/5153/explanation.jpg
I wrote these lines, but I don't know how to make it work :
-- size of the object
dim_selobj = (selobj.max - selobj.min)
-- object.min pivot
selobj.pivot = selobj.min
-- object coordonate
selobj_x = selobj.pos.x
selobj_y = selobj.pos.y
selobj_z = selobj.pos.z
for i = 1 to 10 do
rot_angle_z = 45 -- theta angle
rot_angle = eulerangles 0 0 rot_angle_z
rotate selobj rot_angle
selobj_copy_x = copy selobj
in coordsys local selobj_copy_x.pos = [-i * dim_selobj[1] + selobj_x,selobj_y,dim_selobj[3]]
between your two posts i changed your script a bit. just run it in empty scene...
maybe this helps you.
the difference is i do work with my last instance/copy instead with the base/start object.
Thank you ! It works !
I'm gonna adapt it to my code and i'll tell you the result. :)
New problem
Every script with a loop done on the rotate will be false if the result is a float value. I'm disappointed to see that 3ds max needs more precisions.
You can read this to see how much it's not precise :
http://area.autodesk.com/forum/autodesk-3ds-max/maxscript/how-to-increas…
Is this what you looking for
http://www.youtube.com/results?search_query=animating+tank+treads&oq=Ani…
I don't know which video to see. But from what i see, there is a spline and I don't want to use it, and moreover I don't want to animate.
The problem in my script is the loop is made on the first object. But the loop should be on the last object created.This is my problem.
Thanks for your help by the way. :)
