I'm trying to find out the issue with mouse events in the listview dotnet control and pressing escape.
At the bottom, is the code.
If you block out all the
on lv <eventname>'s, then there's no error.
The only way to remove the error and keep the code is to add this:
on lv KeyUp e do (
if e.keyvalue == 27 do lv.dispose()
--print (e.keyvalue as string + " - Escape KeyUp")
)Which isn't ideal.
Here's the full code, just run it and hit escape a few times for the JIT error to appear:
try(destroyDialog lvRol)catch()
clearListener()
rollout lvRol "ItemMouseHover - Help Required" height:300 width:500
-- functions
local _lvInit, _lvPopulateList, _lvAddColumns, _lvIsFormReadyToFocus
dotNetControl lv "system.windows.forms.listView" height:(lvRol.height) width:(lvRol.width-1) pos:[0,0]
fn _lvInit lvArg = (
lvArg.view = (dotNetClass "system.windows.forms.view").details
lvArg.FullRowSelect = true
lvArg.MultiSelect = true
fn _lvPopulateList lvArg = (
rows = #()
for x in objects do (
li = dotNetObject "System.Windows.Forms.ListViewItem" x.name
li.tag = dotnetmxsvalue x
li.subitems.add ((classOf x) as string)
li.subitems.add (((x.wireColor) as point3) as string)
append rows li
lvArg.items.addRange rows
fn _lvAddColumns lvArg columnsAr = (
w = (lvArg.width/columnsAr.count)-1
for x in columnsAr do (
lvArg.columns.add x w
on lv MouseCaptureChanged do (print "MouseCaptureChanged")
on lv MouseClick do (print "MouseClick")
on lv MouseDoubleClick do (print "MouseDoubleClick")
on lv MouseDown do (print "MouseDown")
on lv MouseEnter do (print "MouseEnter")
on lv MouseHover do (print "MouseHover")
on lv MouseLeave do (print "MouseLeave")
on lv MouseMove do (print "MouseMove")
on lv MouseUp do (print "MouseUp")
on lv MouseWheel do (print "MouseWheel")
on lvRol open do (
_lvInit lv
_lvAddColumns lv #("Object", "Class", "Wire Color")
_lvPopulateList lv
createDialog lvRol
Comments (7)
Narrowed down the problem
I've been revisiting this issue today and I've narrowed down the problem to the MouseDown event handler.
Removing this removes the error completely.
See line 45-48 of the below code.
it must be something else that causes this error.
I've checked your code in max2014 and it works fine
I'm using 2020
Thanks for checking this. Just to confirm that you clicked inside the listview before you pressed escape a few times?
sure, I clicked whereever possible
Just checked it in 2020 now and I confirm that it throws an error on esc
Oh, that's good to know. I was sure I was going mad! :P Thanks.
I'll check to see if this has been fixed with a service pack or send this on to them.
one thing I noticed is there are no sender and event parameters. Did you try with them already?
That's been done too. Have you tried in 2020?
