listbox to multilistbox convert
By JokerMartini · 2011-05-18
Below I have a listbox that works exactly the way I want it to. Allowing users to move objects up and down, remove, add and clear. However some of those features to not work when changed over to a multilist box. Which is what I need because it allows for multiple objects to be selected. I just cant figure out how to get the moving up and down to work as well as the remove with multilist.
Here is what i have that works for listbox.
local AnimObjs = #()
rollout rlD ""
ListBox lbxAnimatedObjects "Animated Objects" pos:[10,7] width:120 height:12
button btnAddAnimObj "+" pos:[10,185] width:24 height:24
button btnRemoveAnimObjs "-" pos:[34,185] width:24 height:24
button btnClearAnimObjs "X" pos:[58,185] width:24 height:24
button btnMoveUpAnimObj"^" pos:[82,185] width:24 height:24
button btnMoveDownAnimObj "v" pos:[106,185] width:24 height:24
on btnAddAnimObj pressed do -- Add Objects
userSel = getCurrentSelection()
if userSel.count >= 1 do
for o in userSel do (appendIfUnique AnimObjs o)
lbxAnimatedObjects.items = for i in AnimObjs collect i.name -- update list with array
on btnRemoveAnimObjs pressed do -- Removes Object fromt list
local currSel = lbxAnimatedObjects.selection
for i = lbxAnimatedObjects.items.count to 1 by -1 where currSel[i] do (deleteItem AnimObjs i)
on btnMoveUpAnimObj pressed do
local itm = lbxAnimatedObjects.selection
if itm > 1 do
swap lbxAnimatedObjects.items[itm] lbxAnimatedObjects.items[itm-1]
lbxAnimatedObjects.items = lbxAnimatedObjects.items
swap AnimObjs[itm] AnimObjs[itm-1]
lbxAnimatedObjects.selection -= 1
on btnMoveDownAnimObj pressed do
if itm < lbxAnimatedObjects.items.count do
swap lbxAnimatedObjects.items[itm] lbxAnimatedObjects.items[itm+1]
swap AnimObjs[itm] AnimObjs[itm+1]
lbxAnimatedObjects.selection += 1
print AnimObjs
on btnClearAnimObjs pressed do lbxAnimatedObjects.items = (AnimObjs=#()) -- Clear List
createDialog rlD 140 225
Comments (8)
JokerMartini
Yeah It was a bit of a challenge to get this working the way I wanted it to. It's a good snippet to have around.
Frances
Thanks for the examples of a code, that's what I really need now. I'm a newbie to this and sometimes I just need to check the right example to figure out where my mistakes come from.
Cheers,
Mathis, free mov to avi converter
JokerMartini
McGreed
Hey thanks again for the help. I ended up fixing it this morning and got it working. This is what I came up with for a solution. I did not change the move down button yet but the move up works.
I think next it would be good to input an error check because it bugs out if you try to move the top item in the list up. As well as have the selection update as the items move up and down.
Great work on helping.
I feel like this is a good base script to have for anyone who wants to use these lists and whatnot. Also considering it will have the tools to modify the list as well.
rollout rlD ""
multiListBox lbxAnimatedObjects "Animated Objects" pos:[10,7] width:120 height:12
local itm = lbxAnimatedObjects.selection as array
if itm.count == 0 then print "Nothing is selected" else
for i = 1 to itm.count do
itmNum = itm[i] as integer
swap AnimObjs[itmNum] AnimObjs[itmNum-1]
print AnimObjs
Anders K. Nielsen
Here I fixed the Move Up thing:
			currSel = lbxAnimatedObjects.selection as array
			if itm.count > 0 do
 				for i in currSel do
 					swap (lbxAnimatedObjects.items[i]) (lbxAnimatedObjects.items[(i-1)])
 					swap (AnimObjs[i]) (AnimObjs[(i-1)])
				AnimObjs = AnimObjs
			print (lbxAnimatedObjects.items as string)
Should be able to do the rest with this. The AnimObjs = AnimObjs might look strange, but for some reason the list wouldn't update unless I did it.
Graph
nutJob approach:
 rollout RO ""
  struct item (name, moveUp=false, moveDown=false, del=false)
  local objArr = for i = 1 to 10 collect (item name:("obj_"+i as string))
  fn sortEM arr =
   for i = arr.count to 1 by -1 do
    case of
     (arr[i].moveUp AND i > 1) :
      arr[i].moveUp = false
      swap arr[i] arr[i-1]
     (arr[i].moveDown AND i < arr.count) :
      arr[i].moveDown = false
      swap arr[i] arr[i+1]
     (arr[i].del) : (deleteItem arr i)
     default : ()
   return OK
  multiListBox mlb "" items:(for obj in objArr collect obj.name)
   button up "UP" across:3
   button down "DOWN"
   button deleteItm "DEL"
  on up pressed do
   for i = 1 to objArr.count where mlb.selection[i] do objArr[i].moveUp = true
   sortEM objArr
   mlb.items = for obj in objArr collect obj.name
  )--END up.pressed
  on down pressed do
   for i = 1 to objArr.count where mlb.selection[i] do objArr[i].moveDown = true
   sortEM objArr
  )--END down.pressed
  on deleteItm pressed do
   for i = 1 to objArr.count where mlb.selection[i] do objArr[i].del = true
   sortEM objArr
  )--END deleteItm.pressed
 )--END RO
 createDialog RO
Anders K. Nielsen
For removing stuff, you can use this:
for i in currSel.count to 1 by -1 do
	lbxAnimatedObjects.items = deleteItem lbxAnimatedObjects.items (currSel[i])
And I think this would work for moving the items up:
	if itm.count > 0 do
		for i in currSel.count do
			swap lbxAnimatedObjects.items[i] lbxAnimatedObjects.items[i-1]
Reply to Anders K. Nielsen
JokerMartini
McGreed
Hey McGreed, that you for the help. I really appreciate it.
As for your code. I feel like its going in the right direction but when I run it does not work. It errors out.
Try this out. Keep in mind this is a multilist not a listbox.
rollout rlD ""
if itm.count > 0 do
print AnimObjs
