First off, I am still very early in learning stages, and am in fact editing/modifying an existing set of scripts to add additional functionality. I have run into an issue with a listbox whereby I wish to be able to adjust it's height according to list.items count. However, it always ends up as a single row instead of the normal height by line count.
Here is an example of what I have attempted to do:
listbox lbx_scripts "" height:25 -- this works and I wish 25 to be max size, but would also like to
-- adjust downwards if item count is less than 25
for j = 1 to displaylist.count do
format "Displaylist.count = %\r\n" displaylist.count --just to show actual list count
if displaylist.count <= 25 then lbx_scripts height: displaylist.count
else lbx_scripts height: 25
Of course the above fails with an error
-- Type error: Call needs function or class, got: ListBoxControl:lbx_scripts <<
I need to know how to access the "height:" property outside of the initial declaration. the listbox named lbx_scripts.height property is only in pixels which appears to be the only height I can adjust outside of that initial declaration line.
Is there anyway that I can access that property to adjust it programmatically?
Your syntax is wrong.
Use this:
Nope two different properties as I explained in the code example.
listboxname.height is different from listboxname height:
the DOT operator affects by pixels the COLON operator affects by number of text lines.
I can't seem to access the COLON version as in:
listbox mylistboxname height:25 equates to a listbox size of 25 lines
listbox mylistboxname.height = 25 gives me a listbox height of 25 pixels.
note no DOT here as DOT height is a slightly different property and is NOT used during construction.
that constructor accesses the height via a different function somehow. the DOTheight is by pixels only.
Is the only way I can do this by approximating the number of pixels used as in
mylistboxname.height = (mylistboxname.count * 10)
to approximate 10 pixels height needed?
