Limited Add Button
By Marc · 2012-10-23
I created a dialogue in 3ds max by script. I'd like to know how to create a limited add view button, let say five views.
Thnx in advance,
Marc
Marc
I tried this script and I found an error on this line:
try(destroyDialog rol_test)catch()
Thank you in advance
:) Marc
Reply to Marc
Works well. How could you find an error on second line. Except you forgef to paste parentheses like in the code that Kostadin post below.
Also you can remove the line "global rol_test" and use simply
try(destroyDialog ::rol_test)catch()
Something like this?
	global rol_test
	rollout rol_test ""
		local viewCount = 1
		button btn_addLimited "Add"
		on btn_addLimited pressed do
			if viewCount <= 5 do
				format "Add view: % \n" viewCount
				viewCount += 1	--	increment the counter with 1
	createdialog rol_test
Change the script to fit your needs.
Reply to miauu
Marc
Thanks for your answer:)
I'm gonna check it in my script ;)
