layer filter select
By dussla · 2012-09-05
always thank you for good answer
i have problem also today
that is layer filter select
i have many layer
( ss-dddd , ss-see , ss-3322 dd-ewww dd-3eee)
i would like to select layer's objects having ( ss-*) layer named
can you understand ?
fajar
if selection.count==1 do
if selection.count==1 do select(for i in objects where i.layer==$.layer collect i)
Reply to fajar
Hi fajar
your method only select all object i one (selection) layer.
i think that dussla want to select all objects with "ss-*" layer name.
Try this
select (for o in objects where matchPattern (o.layer.name) pattern:"ss-*" collect o)
Reply to Willian Kim
sicolet
Selecting by layer property
I am trying to select objects in layers that have a portion of a name and only objects on the layers that are not frozen. The below script works for selecting all of the frozen objects. How do I select the unfrozen objects?
select (for o in objects where matchPattern (o.layer.name) pattern:"*SS Hor*" and (o.layer.isFrozen) collect o)
Reply to sicolet
use this code
select (for o in objects where matchPattern (o.layer.name) pattern:"*SS Hor*" and not o.isFrozen collect o)
