hallo,
i'm very new to scripting and currently i had to subdivide a very big mesh by element that have a maximum number of vertices of a uint (65536) value.
but when i select part of the elements i can get only the number of faces selected.
how i could achieve this?
currently i select the subobjectlevel 5 (element) for a mesh
with $.basemesh.mesh. i access the mesh, but how i get the element sub-selection (the selected part of the selected mesh)?
thank you for your time and have a good year.
thank you for your script, miauu, it works very well
cheers!
The code below will works only with Editable POly or editable Mesh objects. You must be in Element sub-object level and you must have several polygons selected.
