keyboard button to rollout button
By zahid hasan · 2020-05-27
Hi, I have a rollout with a few button which i want to link to any keyboard key for easy access. even shift or alt key will do. I am not sure how to link the rollout button with key.
on keyboard.shiftPressed() do
(btnnext.pressed())
Comments (8)
Panteleev Sergey
If you want to keep it simple then use a timer and check for any key combination on tick event
	isKeyDown = (dotNetClass "managedservices.keyboard").isKeyDown
	keys = dotNetClass "system.windows.forms.keys"
	show keys
	while not keyboard.escPressed do
		sleep 0.05
		if isKeyDown keys.Space and isKeyDown keys.ControlKey do
			format "Ctrl + Spacebar is pressed\n"
Using macros for such task is an overkill, imho.
Reply to Panteleev Sergey
zahid hasan
Thank you.
I shall try to implement it, and let you know.
Its very basic dotnet, still i shall need a bit time to understand it properly and tweak.
Really appreciate your quick replies.
Reply to zahid hasan
Panteleev Sergey
of course it freezes max, it's just an example of the idea ;)
Use a timer control in your rollout and do these key-combination checks inside its tick event.
another example:
try(DestroyDialog ::test)catch()
rollout test "Detect Key Press" width:214
	timer clock "testClock" interval:100 -- 10 times a second
	local isKeyDown = (dotNetClass "managedservices.keyboard").isKeyDown
	local keys = dotNetClass "system.windows.forms.keys"
	CheckButton ctrl "Ctrl" width:40 pos:[4,4] across:4
	CheckButton shift "Shift" width:40 pos:[46,4]
	CheckButton alt "Alt" width:40 pos:[88,4]
	CheckButton space "Spacebar" width:80 pos:[130,4]
	fn CheckKeys =
		-- for alt, ctrl, shift & esc we can use these
		if alt.checked != keyboard.altPressed do alt.checked = keyboard.altPressed
		if ctrl.checked != keyboard.controlPressed do ctrl.checked = keyboard.controlPressed
		if shift.checked != keyboard.shiftPressed do shift.checked = keyboard.shiftPressed
		-- for any other keys
		local space_down = isKeyDown keys.Space
		if space.checked != space_down do space.checked = space_down
	on clock tick do
		CheckKeys()
		format "tick...\n"
createDialog test
Create a macorscripts to press the keys on your toolbar.
For example:
macroscript myMacro_btnnext
category:"mycategory"
tooltip:"TOOLTIP NEEDED"
buttonText:"TEXT NEEDED"
	on execute do
		if myRollout.open then
			btnnext.pressed()
			--	"run something else"
macroscript myMacro_btnPrev
	on execute do
			myMacro_btnPrev.pressed()
Reply to miauu
zahid hasan
Its a wonderful solution. Thank you Miauu.
All i have to do is assign hotkeys to that macro.
