For Some reason I'm having a hard time getting the listBox with in a custom attribute show its items. I can add them just fine and when i look up the array with in the listener the information is there, but when I look at the list Box it is empty
ah=(EmptyModifier())
caDef = attributes caName
Parameters Params Rollout:RO
refNodes type:#maxObjectTab tabsize:0 tabsizeVariable:true
)--end Paramaters
Rollout RO "Test"
ListBox P_list "List"
editText P_Name "Name"
button P_Add "Add" across:2
on P_add pressed do
append P_list.items P_Name.text
)--end Rollout
)--end Custom Attribute
addModifier $ ah
custAttributes.add ah caDef
append AH.refNodes (nodeTransformMonitor node:$ forwardTransformChangeMsgs:false)
For now this is a simple example but i can not get it to work properly. Am I missing information somewhere like within the paramater block or does listBox just not like Custom Attributes.
The Correct Code
Hey Everything is fine in your code except the APPEND line...
Correct code copy and paste:
)--end Paramaters
Rollout RO "Test"
on P_add pressed do
P_list.items = append P_list.items P_Name.text
)--end Rollout
I think the problem is that to see the update in the listbox you need to update the items variable with a new array, instead of just appending items. Check out "How do I update the items in a dropdownList or listBox?" in the maxscript reference.
