Is there quick/stable way to remove all hierarchy in a *.max file?
By Edward Snowden · 2017-04-10
Is there any code line to remove all hierarchy in a max scene faster (and more stable) than doing "New>>Don't Save>>Keep Objects" procedure?
I saw this mentioned in a old topic but they didn't make it to the end:
scriptspot.com/forums/3ds-max/general-scripting/new-keep-objects-no-prompt
I've got several of file need do this (not automatically) but manual when a person open the given file to work he needs remove all hierachy. But 3ds max was hanged/crashed by doing so. Is there anyway to run this steps without hang/crash on those files. Thanks for reading.
TsveTan
mergeMAXFile
I think this option can be achieved using merge function. Try it manualy (trough max interface) to see if you can load successful hierarchy, animation, materials etc. Then maybe one from the scripters here can write it, it is a short solution.
Reply to TsveTan
Edward Snowden
not merge
But I want remove all hierarchy as the way "New>>Don'tSave>>Keep Objects" does, not loading them. Might be my bad English make you misunderstand the issue here.
Robert
Explanations
What do you call hierarchy ?
Layers structure, parents structure, ... ?
Reply to Robert
Edward Snowden
This's what I think about it...
Hierarchy in this 3ds max dialogue box - imgur.com/DyXSj1Y
I'm not a script coder so I'll try to explain what I mean. There're files that I try run all the Cleaner type scripts but they only decrease file size to some point. After that point, there's no script I could find to remove junk or unnecessary data on max file. There's file with a simple object with filesize like 300MB and only procedure "New>>Don't save>>Keep Objects" restore it to <100KB (no any remaning notetracks, animalayercontrol, particleview, reactor collisions, linkcomposite etc...).
So I wondering what left in those files that no script could purge? New scene (Keep objects only) seems only way be able to remove those last junk in a 3ds max scene (of course with the cost you lost all key/animation, links, group, etc...). But sometime I've to clear up the file to its optimized size before go on next step.
