Inverted Archs
By JokerMartini · 2013-03-14
So I'm working on generating positions in this circular fashion and I've the outer circle and linear parts working. I'm not sure how to get the inverted archs to work appropriately. I was hoping to get some help on that. If you look at the picture I got the green and yellow parts working but not sure how to calculate the red? Script is below.
http:\\www.jokermartini.com/myStuff/circle.jpg
Feel free to play around and change up the columns variable to any number higher than 3.
steps = 6
height = 0.0
width = 30.0
len = 30
radiusX = 15
radiusY = 15
fourCorners = #()
rounded = .5
delete objects
/* Create Circle */
columns = 4 --don't got lower than 3
columnAngle = 360.0 / columns
subCounter = 0
clearlistener()
/* Create Corner Points */
for c = 1 to columns do
calcX = radiusX * cos((c-1) * columnAngle)
calcY = radiusY * sin((c-1) * columnAngle)
cornerPos = [calcX,calcY,height]
point pos:cornerPos size:4 wirecolor:blue
append fourCorners cornerPos
subCounter += 1
/* Create Sub Points */
subColumns = (steps*columns+columns)
subAngle = 360.0 / subColumns
for s = 1 to steps do
/* Circular Calculations */
subCounter += 1
calcXRadial = radiusX * cos((subCounter-1) * subAngle)
calcYRadial = radiusY * sin((subCounter-1) * subAngle)
circularPos = [calcXRadial,calcYRadial,height]
point pos:circularPos size:2 wirecolor:green
/* Linear Calculations */
calcXLinear = radiusX * cos((c) * columnAngle)
calcYLinear = radiusY * sin((c) * columnAngle)
nextCorner = [calcXLinear,calcYLinear,height]
linearPos = (cornerPos + ((nextCorner-cornerPos)*(((s as float)/(steps+1)))))
point pos:linearPos size:2 wirecolor:yellow
append fourCorners circularPos
/* Inverted Circular Calculations */
JokerMartini
Thanks bud.
A simple solution how to get position of "MIRROR-RED" point.
