Instances in sweep modifier
By David Ganderup · 2016-02-14
Hi there
I have a quistion regarding custom shapes in the sweep modifier (instance shapes).
The custom shape I will be using have a modifier in the stack (ex. Edit_Spline).
When I add my sweep manually both the baseobject and the modifier is an instance (see the link).
https://www.dropbox.com/s/ieh5thty21zv9t3/sweepProb.jpg?dl=0
But when I use my script only the baseobject is an instance:
sweep01 = sweep()
profil = $Rectangle001
addmodifier $ sweep01
sweep01.CustomShape = 1
sweep01.shapes[1] = profil
sweep01.AssignCSType = 2
sweep01.PivotAlignment = 5
What am I missing here?
Regards
David
fajar
addmodifier $ (copy sweep01)
you want a copy insted?
sweep01.shapes[1] = $Circle001
for i in selection do addmodifier i (copy sweep01)
Reply to fajar
David Ganderup
Hello Fajar
I want to get the same result as when I do the process manually, so that the top level in the modifier stack is an instance.
Regards
David
