If the checkbox for display in material editor is checked True how do I make it an instance of the Material placed in the Material Override for Vray?
--http://vray.us/vray_documentation/index.shtml
-- renderers.current.adaptiveSubdivision_maxRate = 10
rollout rlAORender "AO Render"
local VDirt = undefined
groupbox gpbxVrayDirt "VRay Dirt Parameters" width:150 height:100 pos:[5,2]
label lbVDRadius "Radius:" pos:[12,20]
spinner spnVDRadius "" fieldwidth:45 range:[0,9999999,10] type:#worldunits pos:[92,20]
label lbVDDistribution "Distribution:" pos:[12,40]
spinner spnVDDistribution "" fieldwidth:45 range:[0,9999999,1.5] type:#float pos:[92,40]
label lbVDFallOff "FallOff:" pos:[12,60]
spinner spnVDFallOff "" fieldwidth:45 range:[0,9999999,1] type:#float pos:[92,60]
label lbVDSubdivisions "Subdivisions:" pos:[12,80]
spinner spnVDSubdivisions "" fieldwidth:45 range:[1,1000,24] type:#float pos:[92,80]
groupbox gpbxSelType "" width:150 height:30 pos:[5,95]
radiobuttons rbtnType labels:#("Override Mtl", "Shader") columns:2 default:1 pos:[9,106]
groupbox gpbxDisplay "" width:150 height:30 pos:[5,118]
checkbox ckbxDisplay "Display in Material Editor" pos:[10,129] checked:false enabled:true
button btnApply "Apply" width:150 height:24 pos:[5,154]
fn AOShaderCreation =
VDirt = StandardMaterial()
VDirt.name = "AO-VRayDirt"
VDirt.Selfillumination = 100
VDirt.diffuseMap = VRayDirt radius:(spnVDRadius.value) distribution:(spnVDDistribution.value) falloff:(spnVDFallOff.value) subdivs:(spnVDSubdivisions.value)
if ckbxDisplay.checked == true do meditmaterials[1] = VDirt
on rbtnType changed state do
case rbtnType.state of
1: -- Material Override
ckbxDisplay.enabled = true
2: -- Shader Option
ckbxDisplay.checked = true
ckbxDisplay.enabled = false
on btnApply pressed do
1:
Print "Override Mtl"
VR = renderers.current = VRay()
AOShaderCreation()
VR.options_overrideMtl_on = true
VR.options_overrideMtl_mtl = VDirt
2: -- Shader Option
Print "Shader"
AOShaderCreation()
createDialog rlAORender 160 184
You're welcome. Shorter version:
Garp
Hey Garp thanks for the help!
Something like this?
Instance
How do I instance a material from the Material Override slot in the render settings dialog to the material editor slot 1?
