Insert a bitmap into the Displace modifier
By Waltez · 2018-02-21
--How to insert a bitmap in the Displace modifier?
--below a failed attempt
--thanks anyway for the attention
--insert Displace
modPanel.addModToSelection (Displace ()) ui:on
-- which script to use to insert the map with its dir?
---$.modifiers[#Displace].bitMap Bitmap filename: "D:\\maps\\Foglia_006_Displacement.jpg"-
$.modifiers[#Displace].strength = 1
$.modifiers[#Displace].maptype = 0
$.modifiers[#Displace].useMap = on
Thanks for your attention
	displaceMod = Displace()
	modPanel.addModToSelection displaceMod ui:on
	map01Path = @"D:\\maps\\Foglia_006_Displacement.jpg"
	bmp01 = Bitmaptexture filename:map01Path
	displaceMod.map = bmp01
