Hi guys, i'm pritey new to max scripting and find myself stuck on this problem.
I have tried searching around but i'm not entirely sure what my search word for the issue should be.
What i'm trying to do:
I have 4 spline circles. and i want to add a shell modifier to each and one of them but i want the shell outer amount to increase, so you get a step effect. first spline circle value 1 second value 2 and so on.
All i manage to do before getting stuck is this:
for i in selection do
addmodifier i (shell outeramount: 2)
so as the noob i am i tought i could add (shell outeramount: i*2).....but i is no integer. its the selected object itself.
Is there then a way to tell max to look for the selected objects position in the collection and then use that number or annything really?
-Minimus
try this one
It's important to select splines in order
If you want different outheramount values then
vals = #(5,10,15,20) --values for four splines
for s = 1 to selection.count do
addModifier selection[s] (Shell outeramount:vals[s])
Thanks!
That worked out great!!
I dint know it was possible to use the for loop like that.
genius Thanks allot.
-Minimus
